Results 1 to 9 of 9
Thread: Anyone know what this is?
05-24-2009, 11:09 PM #1
05-25-2009, 08:31 AM #2
Re: Anyone know what this is?
Not to any crawlspace I'm guessing or you would have crawled down into it right?
05-25-2009, 09:04 AM #3
Marc,
Where were you standing, in the attic looking down? In a basement looking down?
05-25-2009, 11:29 AM #4
If I am looking at the picture right and you are looking down from the fire box then it is a ash pit they used them in coal fireplaces there are normally a clean out on the floor below I have a house that has 2 of these one on second with a cleanout on the main floor and the one on the main level has the clean out in the basement
05-25-2009, 05:11 PM #5
Oops, I should have said where I was, sorry. I was in the attic looking down at the fireplace where the it comes thru the ceiling.
05-25-2009, 05:26 PM #6
You may be looking at a "dummy" flue built to create some sort of aesthetic effect below the ceiling line in the structure's interior. It's not properly lined as would be a functional flue.
In terms of thermal performance, this "hole" may be an enormorous energy leak if all that separates the conditioned space of the structure from the attice is a single wythe of brick. If that's the case, suggest plugging this "hole" with insulation.
05-25-2009, 07:34 PM #7
Yea, interresting... I thought it was an after thought or mistake.
05-25-2009, 11:29 PM #8
You guys are so informative. I was going to say it was a hole in the floor.
05-28-2009, 10:34 AM #9
Marc,
It may also serve as a fresh-air intake into the FP??? Did you see an openings/vents on the insides of the firebox? Is that insulation that is down inside the opening? Hopefully not.
