Thread: Opinions on this fireplace?
06-22-2009, 07:39 PM #1
In a 40 yr old house, this fancy corner feature is cracked and and starting to tip off the metal shelf support. There is work to do to the chimney outside so I said to get the mason to check this. Maybe put in a steel post?
The 4th pic is the flue for the oil furnace. Can a mason fix that with fireclay or mortar? I suggested a metal flue liner as alternative.
06-22-2009, 07:46 PM #2
Re: Opinions on this fireplace?
Not sure about the cause or remedy in pics 1-3 John but pic #4 defintely needs a new flue liner.
06-22-2009, 08:10 PM #3
06-23-2009, 04:37 AM #4
06-23-2009, 11:47 AM #5
Thanks all. I'm trying to increase my masonry knowledge. No problem with the obvious stuff, it's the small cracks and patches I'd like to be firmer on.
I know this chimney could use a cap and a cricket flashing too. Not bad for the age though.
06-29-2009, 04:38 AM #6
06-30-2009, 06:18 AM #7
