Thread: flue at eave
08-11-2009, 04:15 PM #1
flue at eave
This is either really wrong or absolutely fine. Either way I have no idea. What is wrong or right about this?
08-11-2009, 04:25 PM #2
Re: flue at eave
It is too short.
It needs to be 2 feet higher than any part of the structure within 10 feet (based on the diameter I am presuming it to be).
What diameter was it?
08-11-2009, 04:48 PM #3
Re: flue at eave
I think about 8 inches.
08-11-2009, 04:49 PM #4
Re:chimney at eave
This appears to be a factory built fireplace. The chimney must be 3ft above the roof and 2/10 where it meets the roof deck. In addition, there is a total min. chimney height measured from the base of the fireplace to the flue gas outlet. This is usually a min. of 12ft.
The termination cap is damaged. It has been smashed to the side about 2-3 inches and the mesh damaged.
The piece of sheetmetal is not an approved clearance reduction system and it may actually cause a problem in torrential rains by haystacking heavy water runoff into the concentric ring of the chimney channeling water down into the home.
Check the mfrs. listed instructions for full info.
