Results 1 to 10 of 10
    Sep 2008
    so so, California
    Default Anyone recoginze this stove?
    Dont see too many stoves in sunny so cal. Someone colored over the name plate. Just wondering the name or manufacture of this baby.
    Default Re: Anyone recoginze this stove?
    Yeah, that's my stove and I want it back!
    Just kidding. It looks like an "Osburn"?
    Question Re: Anyone recoginze this stove?
    Do you see anything wrong with this installation or that you would write up?
    Bob
    If its a wood stove then the clearance out front of the door is not great enough, minimum 18" horizontally out. Should be non combustible flooring, extend tile out.
    Are we sure this is not some sort of secondary heat exchanger?
    Sep 2008
    so so, California
    Im good with what is wrong with it and it's install...just need a manufacture.
    Much thanks
    Paul Johnston's Avatar
    Paul Johnston Guest
    From the looks of the carpet it has not been used.
    Jake T Johnson's Avatar
    Jake T Johnson Guest
    It's called an Orley.
    Dec 2007
    Oklahoma
    Cool Orley EPA certs.
    Orley's Manufacturing Company, Inc.
    Cougar G-225 2.70gm/hr
    9100-36200
    72
    Catalytic
    Leopard U245,U246,UO245,UO246; Panther F245,F246
    3.50 gm/hr
    9100-39000
    72
    Catalytic
    As of 22MAy09 stoves certified to EPA Phase II. If you cannot prove this is one of these stoves, it probably would not be allowed to be burned in any air quality district in so. cal.
    Sep 2008
    so so, California
    Wow, you're the man, thanks.
