    Default Brick overhang at chimney
    Any brick masons out there? I'm wondering what you make of this brick installation around a metal flue type chimney. I've seen some overhang before but not to this extent. I'm wondering why it was done this way (i.e. framed improperly) and what if any comment would be appropriate. Thank you.
    Default Re: Brick overhang at chimney
    Rod - Photo?
    I'm sorry John. I forgot to add the photo and re-submitted a different post. I didn't know I could add a photo afterwards. Please see the previous post with pictures.
    thank you,
    p.s. Can i delete this post?
    Rod - I didn't realize you had another thread on the same subject.
