03-01-2010, 01:23 PM #1
What am I seeing in the smoke chamber
WB Fireplaces are definitely not my strong point - I just don't see enough of them.
Picture was taken from just above the damper in a small Rumford style fireplace - probably originally a coal burner - which is now being used to burn wood (one small log at a time).
This is the best picture of the flue I could get, I barely got the camera passed the damper, and I had no access to the top of the chimney which was located on a steep a snow covered roof. Unfortunately, I did not get a usable picture of the firebox, so I grabbed the one attached from the listing.
I'm trying to understand what I'm seeing here: Extremely heavy creosote buildup? Deteriorating parging on the back of the smoke chamber? Deteriorating mortar between the bricks? Something else?
This FP will get a recommendation for Level II for other reasons, but I would like to better understand what I'm seeing.
Thanks.
03-01-2010, 02:13 PM #2
Re: What am I seeing in the smoke chamber
That's a pretty rough flue, and missing mortar and gaps. As a coal burner they were never intended to burn wood to my knowledge. It sure looks like its gonna need upgrading.
The top of the chimney should have a masonry cap as its current set up is prone to water/freeze damage.
03-01-2010, 04:09 PM #3
There was obviously a moisture problem before, the cap at the top of the chimney is recent, birdscreen may mean they had more than water issues.
03-01-2010, 04:11 PM #4
Most imprtantly though, this solid fuel chimney has no flue liner,whether masonary or otherwise.
03-08-2010, 05:11 AM #5
It's a parged, unlined flue unsuitable for use.
If considering relining, make sure you check for the required 4" air space behind the firebox construction. We usually do a level 2 and end up installing an electric fireplace, a gas direct-vent insert with liner(s) or a pellet appliance with liner in these.
Bart
