Results 1 to 2 of 2
    Jody Humbert's Avatar
    Jody Humbert Guest
    Question Chimney flue location
    Is this an acceptable set up for a metal chimney flue. It appears to be a double walled flue. It is wood burning and passes through the second floor exposed in a closet. Clothes racks have been added. Home was built in the late 60's. I realize the clothes should not be that close to the flue. Shouldn't this be enclosed? Thank you for your comments.
    Oct 2007
    Wichita, KS
    Default Re: Chimney flue location
    Quote Originally Posted by Jody Humbert View Post
    Jody,
    The flue system must be enclosed with the proper clearances to combustibles as listed on the chimney.
    Bart Ogden
    Wichita, KS
