Results 1 to 10 of 10
    Sep 2008
    so so, California
    Default Vent clearance to condenser
    Lots of fireplace issues lately. I looked this model up and there was no clearance to anything but gas meters, windows, walls etc... Maybe this is okay? Conventional wisdom tells me this is probably not correct. Any suggestions?
    Default Re: Vent clearance to condenser
    Any suggestions?
    Typical Manufactures Installation Instructions for outside condenser ( check your model) is minimum 12 inches from the wall , 36 if it's the access panel side & cannot be under a water runoff.
    Move the condenser Not Installed per Manufactures Installation Instructions.
    James Duffin's Avatar
    James Duffin Guest
    I would also check the clearances for the condensing unit. If that is corrected you may solve the problem with the fireplace vent too.
    Sep 2008
    so so, California
    Now I feel stupid...thanks
    A whole new meaning to power vent for a fireplace. Turn the AC on and suck the flames out the vent
    James Duffin Guest
    It's nice to have a vice president of the club!
    Sep 2008
    so so, California
    I dont know even want to know why i didn't think of that. It's kinda like misspelling "the". Must be the age catching up to me, I just hit the half-way mark this month...the big 40.
    James Duffin Guest
    You have just entered the "Twilight Zone" (the ones in color of course). I am a member of the black and white "Twilight Zone".
    Andy Jarchow's Avatar
    Andy Jarchow Guest
    I feel your pain!!
    Happy B-day
    mk
    Obstructions, partitions, alcoves, projections.Also, what's in the center? A large FAN. What is the side facing? an inlet for same.Clearance from mechanical vent air intake.Clearances from all other objects - heat, etc. Check your codes, which the mfg instructions also refer to. Needs to be able to intake combustion air as well as exhaust corrosive, etc. nearby surfaces.
