Results 1 to 3 of 3
    Default Fireplace separation from furnace return
    Where, exactly, is the min 10' separation documented?
    To what types of fireplaces does it apply?
    Is it expressly documented somewhere for wood burning stoves as well?
    Can someone provide the exact wording?
    Default Re: Fireplace separation from furnace return
    2005 Oregon Residential Specialty Code
    Look under M1602 (this is from the Oregon Residential Specialy Code mechanical code section).
    Hope this helps
    Thanks. Per that site its 1602.2 Exception 2.3
