Results 1 to 3 of 3
    Default hearth extension
    The buyer had the good sense to contact a specialist to check out this fireplace, so I deferred the whole thing, but... this hearth extension can't possibly pass muster can it? Not the best photos. I can't imagine there's any kind of acceptable material under the stone.
    Smile Re: hearth extension
    It depends upon the listing and what's under that HX. If its concrete, no problem. If it is combustible, there may be a problem. That thicker stone appears to be about 15" out. Most 36" openings require a min. 16" then 20" for 42" or larger, just like in 211. However, the chance of a sheet of 1/2" Micore CV 230 or equivalent being under there are slim to none so Good Call John!
    BTW, illegal aftermarket grate.
    What brand?
    Bob
    Default Re: hearth extension
    What brand?
    Bob
    Thanks Bob. Since the buyer was going to have a specialist look at it anyway, I barely checked it out. There were quite a few other items in the house to spend my time on. Didn't identify the brand. I think the odds of there being proper material under the extension are none-to-none. It's a plywood subfloor. This was in Harleysville, where I seldom venture.
