Results 1 to 10 of 10
Thread: creosote in attic
02-11-2011, 06:58 PM #1
creosote in attic
How would creosote get into the attic other than a major chimney probelm? This was found on the framing directly next to the chimney penatration in the attic.
02-11-2011, 08:38 PM #2
Re: creosote in attic
02-11-2011, 09:16 PM #3
Gunnar,
I picked it up and smelled it. It was the same smell as the sticky stuff that was at the top of the chimney.
02-11-2011, 10:20 PM #4
John,
I can't imagine where it might have come from, if not the chimney. Pretty scary.
02-12-2011, 02:55 AM #5
I would suspect either a breach or hole in the chimney inside the attic or house or maybe the creosote is finding a way back into the attic through a roof vent. Was the substance you saw in th attic in close proximity to the chimney structure?
02-12-2011, 10:05 AM #6
Could also be getting there from before the chimney - fire box, smoke shelf breach, even a from a breach or fire in the ash dump through the wall cavities or other bypasses, or perhaps some sort of fresh air intake breach. Might also be oozing/dripping in from the outside surface of the roof, down wind vent boot or at the roof/chimney junction or elsewhere.
Deposited materials may have also been carried back into the attic via ventillation openings in same, such as gable, ridge or eave vents, turbine vents, exhaust fans or their ducting/venting and breaches in same or "whole house fans".
May have been a fire already, not neccesarily in the firebox, not neccessarily reported, someone might have burnt a bunch of plastic or other inappropriate material in the firebox itself. One of the first pics looks like white paint over patching or some sort of parging with charred wood just below and underneath, with a slice of some sort of fiber or board material just below, but not really sure what's being photographed above the black specks.
Whatever might be the source or cause - an investigation and inspection by a qualified specialist should be undertaken. Appears to be unlined. Some historical inquiry regarding property history, permits, modifications, neighborhood perils, fire department visits, insurance claims, news reports, might be further warranted.
02-12-2011, 04:55 PM #7
02-13-2011, 09:11 AM #8
02-13-2011, 11:58 AM #9
I would be more likely to suspect the deposits if from above are from a LACK of recent repair or maintenance to flashing, roofing, etc. from the conditions photographed from the exterior, and that the photographed collections/deposits are making their way back into the attic, perhaps added in their entry/transport by the effects of Maryland's Winter winds, ice, snow, and thaw effects upon the structure.
Originally Posted by John Kogel
As mentioned previously, it also could be stack effect venting along the exterior of the chimney from a much lower breech or defect.
Either way, an experienced professional needs to inspect and determine, cleaned, and remediated and/or corrected.
02-18-2011, 05:55 AM #10
Hard to tell from the pictures, but often around masonry chimneys small bits of roofing work their way under the flashing over time and land on the insulation and rafters near the chimney. In my area we have quite a few chimneys that have never been used despite being 20+years old (it stays pretty warm in Savannah, GA) and I see this all the time when doing chimney inspections.
The little balls look like tiny bits of creosote, but if you get a look up into where the flashing is around the chimney where it penetrates the roof, you may see that's where the tiny bits are coming from.
When there's a breach in the chimney you'll see evidence of it on the chimney itself in the form of staining or creosote stuck to the chimney.
