04-15-2011, 10:34 AM #1
Gas Furnace combustion air intake
This 90+ gas furnace is using combustion air from the garage and is located near the water heater flue pipe. My concern is the potential for the air intake to draw in flue gases from water heater.
04-15-2011, 01:27 PM #2
Re: Gas Furnace combustion air intake
04-15-2011, 02:35 PM #3
Thanks Scott, I just don't see it done like this very often.
04-15-2011, 08:28 PM #4
That's not a proper way to support the thermal expansion tank, but I'm sure you wrote that up already.
04-18-2011, 10:49 AM #5
If the furnace is pulling in combustion gases from the water heater then I'd be looking at the W.H. for drafting concerns. Also, combustion gases are very corrosive and wreak havoc on heat exchangers.
04-19-2011, 08:42 AM #6
I would check that combustion air to garage space is OK for combined BTU's of furnace and H2O heater. By volume it would require a rather large garage to meet the combustion air requirement.
