Results 1 to 3 of 3
    Feb 2011
    Ohio
    Default Proper way to measure Hearth Extenstion
    Does any one know if the hearth extention on a masonary fireplace should be measured out from the "front " or "rear" of the facebrick? See photo.
    Thanks.
    Default Re: Proper way to measure Hearth Extenstion
    Front, the way you've got the tape. That hearth needs to be wider.
    I've seen people lay a row of tiles across the front for a simple upgrade.
    Sep 2008
    so so, California
    Is that a raised foundation? If so, I believe there shouldnt be any wood below the hearth extension-check with Bob Harper, he'll know for sure.
