Results 1 to 14 of 14
01-14-2012, 09:29 AM #1
Another award-winning Philly chimney
60 year old row house, almost completely rehabbed, and a pretty good job, too, except for this. The chimney isn't in use anymore, but still...
01-14-2012, 11:13 AM #2
Re: Another award-winning Philly chimney
Is that a shared chimney or does that gem belong entirely to your client?
01-14-2012, 11:34 AM #3
01-14-2012, 11:56 AM #4
If there was a Playboy just for chimneys, that crap pile would be the playmate and centerfold of the month.
01-15-2012, 07:51 AM #5
I didnt think it got that windy in Philly. Shouldnt have a draft problem.
Judging by the nice lean, I would suggest at least one pipe is no longer connected properly.
01-16-2012, 06:31 AM #6
This a perfect example of why ALL homes should be inspected and especially why roof access is a must, within safety reasons of course. I'd use this photo to illustrate the need for inspections, as if we need more.
01-18-2012, 08:16 PM #7
Another reason I avoid Philadelphia....
these are easier....
and pay the same....
01-19-2012, 06:00 AM #8
C'mon Joe. You're getting soft.
01-19-2012, 06:31 AM #9
John,
Was this a 2 story or a 3 story roof and how did you access it ? Any skylight ?
01-19-2012, 12:25 PM #10
01-20-2012, 08:43 AM #11
John,
Most of old Baltimore row homes have a skylight, solution to the light and air requirements for all rooms. Thought that Phil houses would have them also. Baltimore the skylights are usually a real mess with tar over tar in an effort to seal them for leaks. After seeing chimney thought skylight might be the same.
Access question was a result of comments about how high some will go before they say its to dangerous. Just curious.
01-20-2012, 09:39 PM #12
Sweet...
Mazza Inspections and stuff...
https://mazzainspections.com
https://waterintrusionspecialist.com
01-21-2012, 04:11 AM #13
01-27-2012, 02:56 PM #14
