Results 1 to 1 of 1
    Jun 2010
    Milwaukee Wisconsin
    Default Copper feed tube..Is this OK?
    Inspected this home Saturday, and after seeing all the other threads about flex tube feeds, within the fireplace itself, just wanted to get some feedback on this set up. Fired up as soon as I turned the valve on, the hole in the floor goes directly to the basement, where the shut off valve is put together with both black steel and galvanized steel pipes. I recommended they have the whole set up checked out to be sure.
