    Clay E White's Avatar
    Clay E White Guest
    Default Direct vent location
    Default Re: Direct vent location
    I've learned via the consumption of a considerable quantity of crow that you have to check each manufacturer's instructions - some allow placement closer than (I anyway) expected.
    Cool Re: Direct vent location
    Per each Fp listed instructions but usually btw 6-12". Some vary if window operable or fixed shut. Different clearances for below, aside or above windows, doors, decks, corners,--enough for a whole page. Cannot generalize or assume.
    Kalamazoo, MI
    Post Re: Direct vent location
    Clay,
    I wouldn't have a problem with it if that large window to the right of it as shown in photo is fixed (i.e. non-operable).
    RJDalga
    http://homeanalysts.com
    Kalamazoo, MI
    Garland, TX
    Quote Originally Posted by Robert Dalga View Post
    Clay,
    Seriously doubt these to be stationary units due to all viewable units having the lower sash screened, but there is always that chance.
