Results 1 to 2 of 2
    brianmiller's Avatar
    brianmiller Guest
    Default gap between firebox / lintel
    Should the gap between the lintel , which supports a stone surround , and the firebox be sealed?
    Inspection Referral SOC
    Jul 2009
    Virginia Beach
    Default Re: gap between firebox / lintel
    [QUOTE=brianmiller;222526]Should the gap between the lintel , which supports a stone surround , and the firebox be sealed?[/QUOTE
    Yes, definitely. Without a good seal there smoke, heat or flame could get into the concealed area and cause bad things to happen.
