Results 1 to 10 of 10
Thread: Make it Fit
    Default Make it Fit
    Hmmmmmm.....not the best pointing work I've ever seen but aside needing some mortar cap repair, it doesn't look too ba.............oops. Never mind.
    Cool Re: Make it Fit
    Why worry? From the curb you can see the flue tile so you can report this chimney is lined....
    May 2013
    Pennsylvania
    Default Re: Make it Fit
    Looks like about half of the chimneys I see (and I'm sure you guys see)...It's a "shortcut" for proper height.
    F.I.R.E. Certified Fireplace and Chimney Inspector/Technician
    CSIA Certified Chimney Sweep
    NFI Master Hearth Professional
    Connecticut
    that's for all the guys that don't go on the roof. Oops, missed another problem, Oops, my SOP will protect me.OOPS, my SOP didn't protect me. OOPSIE!!!! By the way Nick, that's my chimney. HAHAHHAHA
    It's OK. Just don't light a fire.
    Question What would you recommend?
    Ok, so we've all had our fun with this. Now, I'm curious what would each of your recommend in your report?
    Default Re: What would you recommend?
    From the bit that we can see here, with metal cladding nailed to it? It's not worth the cost of relining.
    Billy, does that model Cat come with rubber treads? I don't think the town would appreciate the footprints that thing will leave on the road.
    Anyway, I'll bet a rope and a pickup could topple that mess and it's pretty short, too.
    That chimney actually vents a gas furnace and gas water heater (no fireplace). My report stated the absence of a flue liner in that section and bricks that improperly constrict the inside diameter of the flue. Have serviced by a masonry chimney professional and all repairs made as needed.
    John your method would leave all the mess the chimney is attached to.
    *heavy equipment can be transported to where you need it.
