Thread: Staining on Factory FP damper
10-24-2007, 06:48 AM #1
10-24-2007, 11:07 AM #2
Re: Staining on Factory FP damper
Looks like rust to me, water is the cause. The question is what is the source. Did you get a look at the cap?
10-24-2007, 12:02 PM #3
Fireplace smoke dampers not equipped with a water-letlerr-outer usually look like that.
10-24-2007, 01:53 PM #4
If they kept the home fires burning, the heat would keep that from happening.
