Results 1 to 10 of 10
Thread: How much is too much?
05-17-2014, 03:30 AM #1
This fireplace built in the 60's has a liner in the chimney flue, but the smoke chamber is very large constructed of brick and without a smooth surface. (the photo is a bit grainy from enhanced lighting)
So when is a the unlined smoke chamber too much?? What are the rules? You can't really say any exposed brick is too much, because "EVERY" brick fire place has some unlined brick in the smoke chamber. Is there a practical approach here without crying "Chicken Little"?
05-17-2014, 10:53 AM #2
Re: How much is too much?
Hi Jim,
I wasn't referring to being burned out but more thinking of having a smooth surface for flow of air, and protection of gases leaking out between the joints of the bricks. With that thought, Isn't that what a liner in the flue is all about?? Why require a liner in the flue and none in the smoke chamber??
05-17-2014, 05:06 PM #3
I will call out all brick-lined chimneys for repair because in my climate, the mortar will be loose and falling out. The point is we can't inspect the liner properly and the risk of a leaking liner is not something to take lightly.
I tell my clients they can have a stainless steel liner installed with a fireplace insert. The airtight door gives them control of the fire and the metal liner solves the flue problem.
I can post a picture of a burned out smoke shelf if anyone wants to see one.
05-17-2014, 06:14 PM #4
05-17-2014, 08:58 PM #5
Two crumbling fireplaces, not 100's of years old.
05-18-2014, 06:15 AM #6
05-18-2014, 08:43 AM #7
05-18-2014, 12:08 PM #8
Fireplaces are for recreation and decoration--neither primary heat nor emergencies per se. Sure, you can use one in an emergency but that is not a stated intent anywhere I'm aware of.
With regard to the smoke chamber, you can comment on whether or not it complies with the current codes and standards or not, does it have combustible deposits that need to be removed (swept), signs of water penetration and damage, modifications, etc. but understand you're on a slippery slope. Once you being looking *into* chimneys rather than *at* them, you enter a new realm. For inspectors in Delaware, by law you must be performing a Level II inspection every time. If you cherry pick what you choose to inspect & comment on or not you not only expose yourself but your clients and anyone who comes into that building. You can Not tell from an untrained visual inspection from the firebox of the integrity of a smoke chamber or its suitability for continued use. For starters, as soon as you see the chamber was not parged, that's enough to call it out right there. The parging is there for two primary reasons: added mass or thickness and aerodynamics. It also aids in sweeping. There are other concerns such as wall thickness, dimensions, clearance to combustibles, offset flue outlet and transition, etc.
If the rest of the chimney passed a Level II inspection (which I'm sure it would not), I would at least recommend removal of the damper and smoke shelf, parging the chamber with a purpose made refractory cement coating. install a top mounted damper/ rain cap/ animal guard.
05-18-2014, 12:22 PM #9
I think what Bob is saying, but in completely different words, is that if you are going stand out in front of a semi-tractor trailer barreling down the highway at 70 mpg so you can tell your client if the grille is dirty, real dirty, or too dirty ... you will need to be able do that rather quickly if you hope to have any chance not to be run over by the charging attorney ... er ... semi-truck ... because you didn't tell your client about all the other things wrong with the truck.
Either park the truck and do a Level II inspection or wave as it goes by. It's for everyone's best interests and safety.
05-18-2014, 02:24 PM #10
I rarely see a fireplace anymore that I do not recommend a Level II inspection on. The masonry on-site built fireplaces almost always have something wrong.
