Results 1 to 11 of 11
		Thread: Think I'll Be Disclaiming This
	09-27-2014, 08:54 AM #1
		So while setting up this inspection, the buyer tells me he wants to measure the length of the fireplace chimney flue interior as he wants to order a wood stove insert with new flue liner. It's a one story roof with low pitch and he asked if I was OK with them coming up on the roof with me. I said OK. I pull the spark arrestor cap off the flue top like I normally do, they take their measurement, and I assume they are done.
Well after we get inside and I'm looking at things, I come back into the basement level family room that has the fireplace to see they have done this.
Alrightythen.
	09-27-2014, 03:45 PM #2
 Re: Think I'll Be Disclaiming This
		Wow!!! That tops just about anything any of my clients have done.
	09-27-2014, 08:26 PM #3
		Funny one, Nick, thanks for sharing.
Sometimes you gotta tell them "First you buy it, THEN you can start fixing it".
	09-28-2014, 10:06 AM #4
 a lot of problems here.
		After they pay for cleaning up the house and buy it, they can get a level II inspection. Chances are that steelform fireplace is rusted out and they cannot be fixed in situ. It must be torched out. The hearth extension is too short. There is not the 16" non-combustible floor protection in front of the stove. That's a "slammer" insert which means there is probably some 3rd degree glazed creosote in the chimney. That chimney should be closely inspected for signs of a chimney fire. The internal passageways of the convection air ducts should be scoped for signs of combustibles or gaps in the mortar as is commonly found in them.
By the time he does it right, he'd be better off blowing that pieced of junk out of there and installing a listed EPA phase II rated hybrid fireplace/ stove and chimney.
	09-29-2014, 05:17 AM #5
 Re: a lot of problems here.
		I've learned to never trust insert installations. In my book they should always have further evaluation.
	10-01-2014, 01:08 AM #6
		So Nick, did you say anything to the client about this, and what did he say? Curious as to how you handled this.
	10-01-2014, 05:06 AM #7
		FORGETABOUTIT
http://www.jjeffzehnder.com/
	10-01-2014, 05:47 AM #8
	10-02-2014, 08:44 AM #9
		People never cease to amaze me. I arrived to one home inspection and found the buyers son tearing up some decking. It needed to be repaired, but I had to patiently explain that he was jumping the gun a bit. And we hadn't even started the inspection.
A couple of years before that, I arrived to find the buyer painting one of the bedrooms. In the last case, obviously the buyers' agent had given them the lockbox code. The unfortunate coincidence was that both homes had the same listing realtor.
Can't remember for sure, but both homes were probably bank foreclosures. Still . . . .
	10-03-2014, 08:14 AM #10
		Mazza Inspections and stuff...
https://mazzainspections.com
https://waterintrusionspecialist.com
	10-03-2014, 07:27 PM #11
