Results 1 to 3 of 3
Thread: Fireplace HE
11-12-2014, 09:46 PM #1
Fireplace HE
Anyone know what the standard is for raised fireboxes (from floor) specifically the size of the HE when there is a raised firebox?
Mazza Inspections
www.mazzainspections.com
Blacklisted.. from all realtors
11-13-2014, 06:25 AM #2
Re: Fireplace HE
2009 (I think) IRC:
R1004.2
Hearth extensions. Hearth extensions of approved factory-built fireplaces shall be installed in accordance with the listing of the fireplace. The hearth extension shall be readily distinguishable from the surrounding floor area.
Dom.
11-13-2014, 08:39 AM #3
Re: Fireplace HE
Gas or solid fuel (wood)?
Either way, it is per the manufacturer's installation instructions, but a gas fireplace will not require a hearth extension - at least not the ones I've seen - provided the clearance distance above the combustible material is met. As I recall, some require 20" of clearance from the bottom of the fireplace to the floor for no hearth below it.
