Results 1 to 2 of 2
    dan orourke's Avatar
    dan orourke Guest
    Default Securing the metal cap
    Inspection Referral SOC
    Jon Randolph's Avatar
    Jon Randolph Guest
    Default Re: Securing the metal cap
    Looks like 2 sections of heating duct modified to fit the chase.
    What happens to the masonry as those screws rust and expand?
    What happens when the wire rusts through?
    I would recommend replacement with a correct cap. I would assume that there is a concrete cap under that sheet metal that has deteriorated, why not replace the damaged cap with a proper concrete cap.
    BTW, damaged caps can allow for damage to the tile flue liner. What did it look like? Even minor spalling of a liner is detrimental.
