    New Mexico
    Default Cracked Fire Brick
    I know it's not brick. I just don't know what it is supposed to be called. I see this pretty often. Do you folks call out for it to be replaced?
    Default Re: Cracked Fire Brick
    I call them refractory brick panels and rarely see a fireplace that has them where at least 1 of the panels is not broken.
    No replacement unless it is not staying in place.
    Wider cracks or chunks missing or falling of, yes, replace it.
    Mar 2012
    Lansdale, PA
    I do not call for replacement with cracks like that. In fact, some manufacturer's instructions even state that small cracks are typical and not a problem (my wording, not theirs).
    Apr 2013
    High Springs, Florida
    High temp fireplace sealant.
    - - - Updated - - -
    www.1stproinspection.com
    Certified Master Inspector
    Like Us On Facebook
    https://www.facebook.com/1stproinspection/
    Jun 2010
    San Luis Obispo
    Firebox liners are what most Mfg call them. Patching the crack can be done but likely will fall out in a season or two and won't match the color. Also for the inspectors, most of the non Mfg replacement panels are only 1" thick vs 1 1/2" or 2" for some fireplaces.
