10-21-2015, 01:34 PM #1
Replace Flex gas line with solid pipe in Fireplace
Hello, I recently had a survey conducted on my house in Illinois to sell it. The inspector came back with the flex gas line needs to be replaced with solid pipe stating 'this is not the acceptable standard installation'. I recently had a tenant move out who installed gas logs. It was originally a wood burning vented fireplace with a gas starter. What type of pipe can I replace the flex line with? Who can I call to have this issue corrected? I'm pretty sure there was solid pipe installed prior to the tenant installing the logs. Approximate cost?
Thank you,
Sue
10-21-2015, 11:32 PM #2
Re: Replace Flex gas line with solid pipe in Fireplace
Mazza Inspections and stuff...
https://mazzainspections.com
https://waterintrusionspecialist.com
10-22-2015, 05:04 AM #3
Call a plumber. Not a tough job and should bee quick. Guess about $200 but that is location dependent. Tell them what you need.
Wood fireplace with gas starter converted to gas log insert using flexible line for connection. Need to change flex line to solid line. You might ask if it is required by your local code.
You will want to check the chimney as you are changing to gas from wood fired. But that should have been in the HI's report.
10-28-2015, 10:11 PM #4
Gas flex is just fine if installed correctly
The inspector needs to get his job back at Taco Bell
- - - Updated - - -
- - - Updated - - -
10-29-2015, 07:12 PM #5
11-01-2015, 10:12 PM #6
Gas log lighter pipes must be piped with rigid steel pipe per CSA std. so the pipe cannot flop around. Remember, it is a burner pipe. The penetration must be properly chinked and caulked where it penetrates the sidewall of the appliance. It should have a throttling valve within reach of the fireplace for lighting and must have an approved shutoff within 6 ft. IFGC does have special allowance for remote shutoff on fireplaces if three conditions met: serves only that one appliance, ready access and properly labeled.
Gas logs can use approved flex connectors per their listing unless local codes specifically prohibit them.
Changing fuels triggers a Level II inspection per NFPA 211.
