    Dec 2007
    Osceola, AR
    Default I use the fireplace all the time, there is nothing wrong with it
    Sometimes you can only shake your head and walk away...
    Alton Darty
    ATN Services, LLC
    www.arinspections.com
    Oct 2010
    MONTREAL QUEBEC-CANADA
    Default Re: I use the fireplace all the time, there is nothing wrong with it
    I will post a shot of last weeks. fire box when I get back in the office. Built in fire suppression.
    Oct 2010
    There was bulk water stream down the fire box walls.
    Maybe it was installed in a unit with a sub panel.
    Looks like someone removed the damper and a few firebricks to get a chimney liner down for a wood insert stove that was later removed but the fireplace was never repaired. Some firebricks, parge with Chamber Tech 2000 and a top mounted damper and Bob's your uncle unless there are other issues with it. About a $1,500-2K repair depending upon local market conditions. Look on the bright side: without a pesky throat damper someone can stand up and hand parge the smoke chamber right up to the first flue tile making a smooth transition that reduces the chance of smoke spillage while improving the chamber's dire durability. Level II inspection triggered.
Tags for this Thread
