Thread: Heat&Glo Fireplace, Model# RH36
12-17-2007, 02:18 PM #1
12-17-2007, 03:06 PM #2
Re: Heat&Glo Fireplace, Model# RH36
Looking at the installation manual for the RH36 I can't find anything that says it can't be installed in an exterior porch like the one in the picture.
http://content.hearthnhome.com/downl...s/4044_153.pdf
12-17-2007, 03:36 PM #3
Scott. What about section 2 and 3?
Location of the fireplace and chimney will effect performance as shown in Fig-2.1 The chimney should
: Be installed through the warm air space enclosed by the building envelope......
: Location of the fireplace in a basement, near frequently opened doors, central heat outlets or returns or other locations of considerable air movement can effect the performance and cause intermittent smoke spillage from the front of the fireplace.
12-17-2007, 04:00 PM #4
I don't know. That section has to due with the chimney structure and not the firebox. I'm going to guess that they make a stainless steel unit that will not rust outside and that is the reason that the RH36 is not for outdoor use. My question would be what it does not state "For Indoor Use Only" on the label.
Truth be known, I have never even thought about looking at the FP units in the outdoor porches. I'm seeing a good deal of them now a days, so I guess I need to start. The battle is going to be that the label on the unit does not say it can or can't be used. Supporting document from the manufacturer would be very helpful.
12-18-2007, 10:27 AM #5
01-09-2008, 09:45 AM #6
Aside from the aesthetics, painting firebox refractory does change the heat signature of the fireplace. From that standpoint alone I would say no.
From the aesthetic standpoint, any paint including high temp. (1,200F) rated will scorch. You will see a truncated cone behind the burner, grate. Due to the shades, it will standout even more than had they left it natural.
Installing any fireplace outdoors presents a totally different challenge from indoor. With such variables in air currents, the heat signature can be radically different from indoors. Therefore, clearances are much more suspect. I've seen the flame leaning hard to one side for extended periods so the side wall of the enclosure gets too hot to touch. Oops!
If you look at the printed propaganda on those outdoor fireplaces, you generally don't see them outdoors in a chase attached directly to the house. They are usually shown in a separate "appurtenant structure" such as an island around the BBQ. This is reminiscent of the old colonial cookhouse. If catches fire, you don't burn down the main house!
HTH,
Bob
01-09-2008, 10:09 AM #7
Bob,
Good point with "If catches fire, you don't burn down the main house!" ...
The outdoor fireplaces I'd seen were a combination (so to speak) of the two types ... separate from the house at a rear porch, on a side or back corner, while 'separate from the house' regarding walls and chase, they were 'common to' the rear porch roof.
