Results 1 to 3 of 3
	04-01-2019, 05:48 PM #1 rubber membrane used for chimney crown rubber membrane used for chimney crownI'm sure this material is not approved for the chimney crown, maybe the roof.
	04-02-2019, 03:51 PM #2 Re: rubber membrane used for chimney crown Re: rubber membrane used for chimney crownNot approved. Often used where there is a significant water intrusion problem and this is a stop gap to buy a few days until the contractor can restore the crown. If that is a solid fuel liner then you do have a much higher risk of fire.
	04-03-2019, 08:01 AM #3
  Reply With Quote Originally Posted by Sam Morris
