    Jerome W. Young's Avatar
    Jerome W. Young Guest
    Default gas line / fixture
    this is a gas line in the attic. Any problems with this lying over a light fixture?
    Default Re: gas line / fixture
    I would definitely write that up. The gas line should be re-routed away from the light fixture and be properly secured according to the manufacturer's specs. In fact, I don't believe it should be lying on top of the ceiling without protection. Someone could run a screw up from the bottom and pierce the CSST.
    Nolan Kienitz's Avatar
    Nolan Kienitz Guest
    Jerome,
    Here is a URL for the Gastite installation guide. Section 4.0 has the installation guidelines.
    http://www.gastite.com/include/langu...IGuide2008.pdf
    Jerome,
    As John and Nolan pointed out:
    4.1 d)
    Protect tubing from contact with sharp objects
    (I.e., the corners of that recessed light fixture.)
    4.1 3)
    Avoid stressing the tubing ...
    (I.e., pulling on that fitting as shown in your photo.)
    4.4 Strike Protection
    Roger thanks
