Results 1 to 11 of 11
Thread: Wooden Cap
    Aaron Miller's Avatar
    Aaron Miller Guest
    Default Wooden Cap
    Anybody ever seen this before? It's a masonry firebox and chimney. I've never seen plywood below the mortar cap?????
    Aaron
    Default Re: Wooden Cap
    Aaron, is the chimney sealed shut? It's hard to tell from the partial pic.
    If it is sealed, the plywood will only last so long before water gets in and rots the wood. If the fireplace is operable, then it's even worse.
    Aaron Miller Guest
    No, it's presently in use. Why would there be plywood there in the first place? I've overseen the building of a few masonry chimneys in my time and there was never plywood involed save for forms in the crawl space.
    Aaron
    David Banks's Avatar
    David Banks Guest
    Aaron
    I think most masons would use corrugated galvanized steel. Some masons use to be carpenters and just can not get away. But wood takes on humidity and cracks the cap. Should be no wood in that area anyway. Could also be a homeowner special
    It likely had a full metal cap at one time that was replaced with what is there now.
    Orlando, FL
    They used plywood to form/set the concrete.
    Aaron Miller Guest
    Shouldn't they have used flashing instead of plywood?
    Aaron
    Cool Re: Wooden Cap
    This is typically done when the chimney is built as a one wythe outer shell and no fill to the flue. It looks like a brick chase with terra cotta flue tiles. When you get to the top, the mason sets plywood to hold a mortar crown.
    This should get a leve III inspection: remove the crown and combustible plywood, inspect the interior and develop a game plan. If it is a chase with more than 4" air space around those flue tiles, a total rebuild would have to be considered or possibly a liner.
    Bob
    And, if I recall correctly ... plywood burns ... doesn't it?
    Richard Rushing's Avatar
    Richard Rushing Guest
    Yes... that plywood is set in place for the mortar cap as a form. That's all. That sucker should not be there.
    Wood should be burned in the fireplace... not on top of the chimney.
    rr
    Aaron Miller Guest
    Thanks to everyone for confirming my doubt that this was a legitimate installation. As EC Jerry said - wood burns. As Richard said - should be burned in the firebox, not at the top of the chimney. As Bob said, I ordered a level III inspection.
    Thanks again,
    Aaron
