Old 01-14-2009, 08:26 PM
MaMa Mount's Avatar
MaMa Mount MaMa Mount is offline
Fiberglass insulation in the fireplace
Can someone please tell me if the yellowish colored fiberglass should be exposed in a metal firebox where the firebox is connected to the flue. There was this insulation that visibly had smoke or soot on it. I couldn't take a picture of it at the time. Anyone have a clue of what I'm trying to explain. Sorry if I sound confusing.
IC Home Inspection Report Writing
Old 01-14-2009, 09:59 PM
Re: Fiberglass insulation in the fireplace
If you can see it from inside the firebox looking up the flue, then something is wrong. If you are seeing it from the outside (before the drywall goes on) then maybe OK. I would recommend checking out the installation manual. If you have the brand, do a google search, lots of info out there on-line.
Allen, Texas 75002
Old 01-14-2009, 10:13 PM
MaMa Mount's Avatar
Thank you so much Mr. Luttrell for taking the time to answer my question. Your help is much appreciated. I feel many on this board are ignoring my questions but i'm only trying to learn.
Old 01-14-2009, 11:43 PM
Ron Bibler's Avatar
Ron Bibler Ron Bibler is offline
Quote:
I think its the blue hair
I had one of them hot boxes today. don't like them... Every one i have ever inspected had something wrong with it.
Make your notes and defurrrrr it off...
Best
Ron
Old 01-15-2009, 12:25 PM
brian schmitt brian schmitt is offline
was this a woodstove,insert,or fireplace? some woodstoves have a fiberglass type blanket above a heat exchanger inside the stove? it is white to yellow and about 2" thick. when i clean my stove i remove the heat exchanger and the blanket in order to remove the debris from the cleaning of the flue system.
  #6 (permalink)
Old 01-15-2009, 12:45 PM
Raymond Wand Raymond Wand is offline
Hey MaMa Mount.
No offense but seeing as you raised the issue about people ignoring you, maybe you should use a real name, and fill out the profile, so people know who they are dealing with. It may very well assist with getting more answers fwiw.
The value of experience is not in seeing much, but in seeing wisely. - Sir William Osler 1905
  #7 (permalink)
Old 01-15-2009, 04:51 PM
MaMa Mount's Avatar
Just for you Raymond.
Maureen Mount
  #8 (permalink)
Old 01-15-2009, 05:22 PM
Jerry Peck's Avatar
Maureen Mount
Click on the 'Contact Us' link at the bottom of the page and ask Brian to change your username. Brian will be glad to do it as we use real names here (have you've been told above).
  #9 (permalink)
Old 01-15-2009, 05:29 PM
Rick Hurst's Avatar
We all owe you a Big Thank You, Raymond.
This space is now available for sale or for lease. Contact your broker if interested. Serious inquiries only.
  #10 (permalink)
Old 01-19-2009, 05:26 AM
Bart Ogden Bart Ogden is offline
Some metal fireboxes with a metal smoke chamber require insulation in this area to allow for expansion and sealing of the transition between the vitreous clay flue tiles and the metal smoke chamber flue tile receiver.
If the insulation is intact and is a gasket, as I expect it is, it shouldn't be an issue.
As with nearly all chimney issues, particularly with real estate transactions, recommend a Level 2 inspection by a CSIA Certified Chimney Sweep or a FIRE Certified Inspector.
With masonry fireplaces, a video camera should be used to thoroughly inspect each flue tile joint for integrity.
Bart Ogden
Wichita, KS
Home Inspector Essentials. The BEST prices for inspection tools.
Similar Threads
Insulation allen elliott Attic Areas: Home Inspection and Commercial Inspection 8 09-12-2008 09:20 AM
Is this insulation? Rick Burkman Attic Areas: Home Inspection and Commercial Inspection 5 06-18-2008 06:30 AM
SPF insulation Frank Bombardiere Attic Areas: Home Inspection and Commercial Inspection 5 05-25-2008 06:09 PM
wet insulation dan orourke Attic Areas: Home Inspection and Commercial Inspection 4 06-24-2007 10:19 AM
Insulation John Stephenson Attic Areas: Home Inspection and Commercial Inspection 5 05-17-2007 05:14 PM
vB.Sponsors
Ad Management by RedTyger
