Old 05-26-2007, 11:13 AM
Bruce Breedlove's Avatar
Bruce Breedlove Bruce Breedlove is offline
Prefab Fireplace Clearances
What are the required clearances from this prefab Majestic M28 fireplace with gas logs to combustibles? I am especially interested in the clearances to the side and above the fireplace.
Bruce Breedlove
www.avaloninspection.com
Old 05-26-2007, 11:53 AM
Eric Barker's Avatar
Eric Barker Eric Barker is offline
Re: Prefab Fireplace Clearances
Bruce, I don't have answer to your question. But I'll raise another one. Does the firebox have vent louvers that are covered up?
Eric Barker
Barrington, IL
Old 05-26-2007, 01:15 PM
Eric,
Not to my knowledge.
Bruce Breedlove
Old 05-26-2007, 08:58 PM
Bob Harper's Avatar
You need the listed installation instructions that came with this Fp. That will state the clearances. Even if this model is still in current production, you would need the manual that applies to this model Fp based upon when it was built. Majestic's Technical Services leaves a lot to be desired but you may luck out and get what you need from them.
Never try to apply general stds. to factory built Fps. There are some units out there with radically different clearances from "the norm".
Eric raises a great point: if there are louvers as for a circulating fireplace, these cannot be blocked. Also, how did they treat the spark strip and gap to the floor? I don't see any Micore or similar insulating board under that stone hearth extension.
Home inspection
Similar Threads
propane clearances John Arnold Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 11 09-04-2008 03:32 PM
Stucco clearances Michael Vasquez Building Envelope: Home Inspection and Commercial Inspection 8 05-11-2007 07:55 PM
Clearances for Panel Jeff Eastman Electrical Systems: Home Inspection and Commercial Inspection 3 05-02-2007 03:53 PM
Wood Burning Fireplace Dale W. Feb Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 12 04-16-2007 03:08 PM
Fireplace Had It's Own Air Handler Unit Nick Ostrowski Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 6 04-03-2007 01:56 PM
vB.Sponsors
Ad Management by RedTyger
