Re: Firebox question
Per the 2009 IRC, 1/4" max. btw firebricks. It does not provide a specification for stone since this would be impractical due to stone's infinitely variable edge profiles.
The intent, regardless whether fireboxes or flue tiles is to use the minimum mortar necessary to bed and bond the masonry units--a novel concept to most masons. The BIA technical notes and other sources have more info. on what constitutes good masonry practice. The BIA has produced the Masonry Fireplace and Chimney Handbook, 3rd ed., which would be one decent Beginner's reference book along with the current edition of your codes and NFPA 211. However, to make sense of it all, I highly recommend you attend the FIRE course, which will also shed light on many other aspects of the home, documentation, liability, and inspection skills.
Good point Matt,
Bob
