Old 06-21-2007, 06:38 PM
David Banks David Banks is offline
Fireplace Wood to Gas
Thanks to Bob and Dale I now look like mad man for Data plates. This Heatilator data plate says wood only.
Dave
Old 06-21-2007, 06:49 PM
Michael Thomas's Avatar
Re: Fireplace Wood to Gas
Man, now *there's* potential liability if you don't know to look...
Old 06-21-2007, 08:54 PM
Bob Harper's Avatar
model, serial#, mfg date code?
David, if you have this info. you can contact HG Tech Services and they can fax or email an install manual. Many things to consider with these units.
OK, yes, I think this particular unit was wood only. This is due in part to the unique arrangement of glass on 3 sides with one long and 2 short sides insteado of the more common "penninsula" style with 2 long and a short end. It may also have simply been money. These units had a very small market niche to start with. It has since been discontinued. They may not have had the extra money to test it for a log lighter or gas logs.
That wood mantel shelf has to go. Appears to be lapped over the black metal face. This unit may have a sidewall clearance that requires it be built out from the wall so there isn't the radiant heat on those walls. That includes the hearth extension usually projecting back behind the unit about 6" as it wraps around. I don't see room for the floor protection under that hearth extension. Probably don't have a Z bend spark flashing from under firebox, down riser and under HX. Defintely don't have clearance to that bongo drum or kids toy.
With the combustible child-proof lock out on the doors, I would check to see if that pilot was lit. If so, they could burn the house down, shatter the glass, or fill the house with CO and BPM.
As for the gas controls, hard to tell what's going on. I see a Robertshaw thermopile only-type millivolt valve and some black iron that looks like a jungle gym. Is this a vented gas log set or did somebody get creative and go freestyle? Is the damper clamped wide open? Soot on both sides of the damper valve plate?
Can't wait to see the termination or pics from the attic. Got any more David?
Glad we're having an impact.
Old 06-21-2007, 10:12 PM
Bob. Gas was turned off. Owner says fireplace not working.(Realtor) Damper was open. Cathedral ceiling so no access in attic. A few more pics. Thats all I have.
Dave
Old 12-02-2007, 09:24 PM
tim lull tim lull is offline
Hi there love the shroud
United Infrared
Similar Threads
Fuzzy wood under front porch Terence McCann Exterior Systems: Home Inspection and Commercial Inspection 8 02-29-2008 08:29 PM
Fireplace support John Stephenson Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 1 06-06-2007 03:10 PM
Wood Structural Panel Sheathing or Siding Used to Resist Combined Shear & Uplift Brian Hannigan Building Envelope: Home Inspection and Commercial Inspection 0 05-23-2007 01:16 PM
Exposed wood joist in return air John Tullous Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 15 05-08-2007 07:27 PM
Wood Burning Fireplace Dale W. Feb Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 12 04-16-2007 03:08 PM
vB.Sponsors
Ad Management by RedTyger
