Old 07-22-2007, 11:53 PM
Mike Pearson Mike Pearson is offline
Wiring inside the chimney area
There is likely ample space BUT is any wiring allowed inside the chimney area between the outer framing and the metal flue? This is a view from the roof of the cable wires hanging out.
Mike Pearson
S. FLA
Old 07-23-2007, 07:04 AM
David Banks David Banks is offline
Re: Wiring inside the chimney area
Mike. This was addressed last week. Scroll down to "Electrical cable in Chimney Chase" Dale Web says OK under certain circumstances.
Dave
Old 07-23-2007, 10:11 AM
Jim Luttrall Jim Luttrall is online now
If a satellite or cable installer did it, it is wrong
I think somebody should start inspecting their work.
If they penetrated the chase, then it should be sealed just like any other penetration, the cables should be properly secured to prevent encroachment into the "xx inch clearance to combustibles" zone. They can't be located inside a airconditioning duct or return.
I will bet they did not seal the penetration at the exterior to prevent water entry and they left insulation out of where ever they had to run their cable.
Mr. Inspector.net, Inc.
Allen, Texas 75002
Similar Threads
Electrical cable inside of chimney chase dan orourke Electrical Systems: Home Inspection and Commercial Inspection 3 07-18-2007 09:29 PM
Inspector needed for Richmond, VA area Jack Feldmann Employment: Home Inspectors & Commercial Inspectors 0 06-21-2007 10:30 AM
Window in combo bath/shower area imported_John Smith Building Interior: Home Inspection and Commercial Inspection 4 04-19-2007 08:49 PM
Kitchen area GFCI Phillip Stojanik Electrical Systems: Home Inspection and Commercial Inspection 6 04-18-2007 11:44 PM
Brick Veneer Exterior Wall 90 deg inside joint imported_John Smith Exterior Systems: Home Inspection and Commercial Inspection 2 04-05-2007 07:52 PM
vB.Sponsors
Ad Management by RedTyger
