Old 07-25-2007, 07:25 PM
Jim McClendon Jim McClendon is offline
insulated chase
Seeing the insulation (paper toward the firebox) made me a little nervous today. Or is that normal?
Old 07-25-2007, 08:44 PM
David Banks David Banks is offline
Re: insulated chase
I use comments such as this.
FIRE HAZARD:
: Most manufacturers have this warning on paper face of insulation. Kraft or foil facing will burn. Do not leave exposed. Can result in injury or property damage. Facing must be installed in substantial contact with an approved ceiling, wall or floor product. Do not place insulation within 3 inches of light fixtures or similar electrical devices unless device is labeled for contact with insulation. Use only unfaced insulation between wood framing and masonry chimneys. Do not use insulation in spaces around metal chimneys, fireplaces or flues.
Dave
Old 07-25-2007, 09:24 PM
Dale W. Feb Dale W. Feb is offline
Re: insulated chase
All clearances requirements on these metal fireplaces, chimneys and vents clearly state “AIR SPACE”. Without the air space the heat is captured. The insulation does a better job of capturing the heat due to it value. This condition may result in overheating, heat migration and ultimately a structure fire.
Now that the fire has started, how do we control the spread? Better write up that missing fire block barrier. You as a home inspector should not be able to see this area if the fire blocking was complete. This is again a very good reason to call for a Level II inspection. If the barrier was complete (like many are) this condition would have gone undetected until the fire. Believe it or not, these are easy fires to determine based on the fire patterns and damage on the protected and unprotected materials. This is where the insurance company starts to ask, “who has been here lately?”
Fuel for thought,
Dale W. Feb, Professional Education For Professional Results
Training: F.I.R.E. Service (805) 552-9958 www.gotoFIRE.com
Inspection/Investigation: F.I.R.E. Associates (805) 552-9954 www.FireAssociates.org
Old 07-27-2007, 08:09 PM
Re: insulated chase
Thanks David...Thanks Dale.
Old 07-27-2007, 10:39 PM
Re: insulated chase
This brings up another question. What if you see a situation where the wall insulation is shifting but has not yet reached the clearance area of the chimney pipe of fireplace? Would you write it up or ignore it?
Fuel for thought
  #6 (permalink)
Old 07-28-2007, 04:56 AM
Mike Pearson Mike Pearson is offline
Re: insulated chase
Dale,
Pssst, Your missing a "s" in professional.
Mike P
S. FLA
  #7 (permalink)
Old 07-28-2007, 08:41 PM
Re: insulated chase
Thank you Mike. That was not very professional of me was it? Can I take one from your Pssst? I'll take your s and raise you two more. Now I have two pair, "S"es and "O"s. This message board is always a gamble.
  #8 (permalink)
Old 07-28-2007, 09:09 PM
Re: insulated chase
Dale
No problem.
I put the extra "S" in there just in case you wanted to take one.
I received your FIRE Service package today. I will look it over this weekend. Thanks.
Mike Pearson
Lighthouse Building Inspections
President Gulfstream ASHI Chapter
S FLA
  #9 (permalink)
Old 07-29-2007, 06:16 AM
bruce m graham III bruce m graham III is offline
Re: insulated chase
Dale,
Fire service packet? Is this something for a class or extracurricular material. If you can can you send me some info, always wanting to learn the right way of things. I find a lot of new construction where the flue pipe is not connected or is being installed upside down.
Bruce
  #10 (permalink)
Old 07-29-2007, 07:10 AM
Phillip Stojanik's Avatar
Phillip Stojanik Phillip Stojanik is offline
Re: insulated chase
Quote:
Not normal and definitely not good. Kraft paper facing aside, it is not good to fill the required "air space" with an insulation product. This only serves to concentrate heat rather than let its dissipate naturally (via gravitational airflow patterns that serve to keep combustion temps below the level of combustion/ignition).
And who forgot the firestopping above?
Once push comes to shove and the fire has already been started, how do we get out of the building alive?
First we make provisions to prevent fire as best we can. Secondly we make provisions to smother/slow the spread of the fire. Thirdly, we provide an early warning system that apprised the occupant that a fire exists. Fourth, we provide emergency escape and rescue openings.
That is the minimum building code that is much embraced/disparaged. Fithly, we pray that all the levels of reduncancy built into the "minimum" building code actually work and that we and our loved ones "make it out alive".
This is true whether its a public high occupany building or a single family residence. Each life is afterall precious.
Similar Threads
Electrical cable inside of chimney chase dan orourke Electrical Systems: Home Inspection and Commercial Inspection 3 07-18-2007 09:29 PM
Electrical cable in Chimney Chase John Stephenson Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 13 06-22-2007 08:24 AM
vB.Sponsors
Ad Management by RedTyger
