Old 10-24-2007, 07:48 AM
Staining on Factory FP damper
Home inspection
Old 10-24-2007, 12:07 PM
Jim Luttrall Jim Luttrall is online now
Re: Staining on Factory FP damper
Looks like rust to me, water is the cause. The question is what is the source. Did you get a look at the cap?
Mr. Inspector.net, Inc.
Allen, Texas 75002
Old 10-24-2007, 01:02 PM
Jerry McCarthy's Avatar
Fireplace smoke dampers not equipped with a water-letlerr-outer usually look like that.
Construction Consultant
Old 10-24-2007, 02:53 PM
If they kept the home fires burning, the heat would keep that from happening.
Similar Threads
Damper stops & fesh air vent David Macy Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 7 01-07-2008 12:51 PM
Child Pool Safety Fence Manufacturer Announces Factory Direct Offices - Emediawire (p Brian Hannigan Pool and Spa: Home Inspection and Commercial Inspection 1 08-24-2007 12:44 PM
No damper on a Heatilator Scott Patterson Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 2 08-07-2007 09:13 PM
Vent Damper neal lewis Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 3 05-30-2007 06:39 PM
Staining on damper Jeff Eastman Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 1 05-08-2007 08:30 AM
vB.Sponsors
Ad Management by RedTyger
