Old 12-03-2007, 03:15 PM
dan orourke dan orourke is offline
Fireplace opening
Old 12-03-2007, 04:23 PM
Gunnar Alquist's Avatar
Re: Fireplace opening
Dan,
I don't see a gap in your photo, but if there is a gap, it should be sealed because there is likely wood framing behind.
What is the circumference of a moose?
Old 12-03-2007, 07:17 PM
Bob Harper's Avatar
To illustrate gaps around fireplaces, try inserting a putty knife or pocket knife for photos.
HTH,
Bob
Similar Threads
Plumbing vent, attic opening Clay White Attic Areas: Home Inspection and Commercial Inspection 4 11-01-2007 02:48 PM
Door (?) opening over stair Clay E White Building Envelope: Home Inspection and Commercial Inspection 2 09-23-2007 07:20 PM
Fireplace help Jim McClendon Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 1 09-14-2007 08:36 AM
Multiple vents through one opening Jeff Eastman Built-In Appliances and Systems: Home Inspection and Commercial Inspection 12 06-06-2007 07:45 PM
Opening at bottom of guardrail dan orourke Building Interior: Home Inspection and Commercial Inspection 5 05-07-2007 06:29 PM
vB.Sponsors
Ad Management by RedTyger
