Thread: Kernerator Incinerator
04-14-2007, 06:31 AM #1
04-14-2007, 06:47 AM #2
Re: Kernerator Incinerator
Kernerator Incinerator Brochure (1925)
04-14-2007, 06:51 AM #3
Nick - Be reasonable. How old do you think Bob is?
04-14-2007, 07:15 AM #4
Well then I better hold off on asking Bob for his take on the flint and steel furnace ignitor.
04-14-2007, 03:11 PM #5
antique inspectors
Ok, I know I'm just a flash in the pan ;-)
The little I'm familiar with, they are basically masonry fiurnaces with factory doors, chutes, etc. There is a roto-dump/ agitatoe lever on most much like you would use burning coal. The hardware provides a check valve apparatus so when burned, it separates the flue from the chute. It also has a cleanout door. The chimney is categorized as Low Heat Residential Category I just like a furnace or fireplace.
Nick, you and John need to learn to respect your elders. John may have a little more snow on the roof than me but I certainly feel older than him. ;-)
