Old 01-11-2008, 12:53 PM
Paul Kondzich Paul Kondzich is offline
Gas line in fireplace
In a fireplace that used to have a gas insert, but now does not, is it OK to have the old gas line capped off in the fireplace. There is a shut off valve.
Paul Kondzich
www.altitudehomeinspection.com
Old 01-11-2008, 02:30 PM
Scott Patterson's Avatar
Re: Gas line in fireplace
Quote:
I don't see a problem with it. BUT.............!
My concern would be with the condition of the innards of the fireplace. What is the condition of the FP, damper, throat, smoke shelf, the flue (tiles) pipe, etc. Inserts can cause a great deal of damage to a masonry FP. At a minimum I would call for NFPA 211 14.3 Level II Inspection.
Scott Patterson
Old 01-14-2008, 04:44 AM
Bart Ogden Bart Ogden is offline
This should trigger a Level 2 Chimney Inspection. The fuel and the appliance has changed.
Sincerely,
A. Bart Ogden, President
Home Safe Hearth & Chimney, Inc.
Wichita, KS
Voice 316-265-9828
Fax 316-265-9890
www.HomeSafeKS.com
Old 01-14-2008, 02:52 PM
Robert Dalga's Avatar
Robert Dalga Robert Dalga is offline
No problem with the capped pipe (unless it's leaking). This is how it is done around here. Thus, if the new owners want to convert to gas logs (you can tell them that a gas line is present).
RJDalga
Home Analysts, Inc.
Kalamazoo, MI
Similar Threads
Fireplace staining dan orourke Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 0 11-04-2007 01:46 PM
Fireplace help Jim McClendon Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 1 09-14-2007 09:36 AM
Venting for gas fireplace Jon mackay Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 3 06-19-2007 06:01 AM
Fireplace support John Stephenson Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 1 06-06-2007 03:10 PM
Outdoor fireplace Jeff Eastman Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 15 06-06-2007 09:20 AM
vB.Sponsors
Ad Management by RedTyger
