Old 01-28-2008, 06:04 AM
Jerome W. Young Jerome W. Young is offline
gas water heater
what is going on here? notice the staining above the burner access door
Old 01-28-2008, 06:10 AM
John Arnold John Arnold is offline
Re: gas water heater
That staining is evidence of back-drafting. Force the heater to fire up and put a mirror down there - it will probably fog up. There are many reasons why this might be happening, from oversized flue to poorly inclined flue connector to blocked flue, etc. etc.
Old 01-28-2008, 07:27 AM
Nick Ostrowski Nick Ostrowski is offline
Maybe the fire extinguisher next to the tank is telling you something.
Old 01-28-2008, 07:42 AM
wayne soper's Avatar
Yes backdrafting should be checked by a pro. Funny thing though is that usually if the unit is back drafting with the access door attached the door edges would be discolored also. They are not on this unit which leads me to believe that the home owner had to re light the pilot and left the access door off for a while. Maybe until those combustibles next to the unit started to smoke. Vis a vie the fire extinguisher.
You kind of have to look at these things like. Now what could I have done here "IF" I was just another stupid homeowner. Which I am, and things of this same stupid nature, I have done myself, even knowing the consequences.
So what can be expected of the general publi? Anything and everything.
This won't be the first time you see this so set up a boiler plate comment to key into your reports for this one.
Without the stupid homeowner comments for sure. HAHA Wayne
Old 01-28-2008, 07:48 AM
Also, looking at the pic again. If that garage door is left open. It is in the garage isn't it? And the door to the home has no auto closer. And the door were left open. The air pressure pushing into the home through the door would pull the flame right out of that unit causing the discoloration and possible asphixiation to the inhabitants of the home. The unit is also required to be be at least 16 inches above the floor level to prevent the gas can, set just out of view next to the fire extinguisher from exploding.
  #6 (permalink)
Old 01-28-2008, 08:33 AM
Rick Hurst's Avatar
It should be 18 inches off the garage floor.
  #7 (permalink)
Old 01-28-2008, 08:48 AM
Jerry McCarthy's Avatar
Check this web-site out: Backdraft Interactions
Construction Consultant
  #8 (permalink)
Old 01-28-2008, 09:46 AM
Jim Zborowski Jim Zborowski is offline
Flame roll out may also be caused by improper oriface size, bad burner, bad control. Also, my guess is tghe inside cover isn't in place either.
  #9 (permalink)
Old 01-28-2008, 03:37 PM
Peter Drougas's Avatar
Peter Drougas Peter Drougas is offline
Did you check inside to see if the stack dropped, creating a barrier to gases.
The exterior markings and the dropped stack seem to go hand in hand when ever I see it.
  #10 (permalink)
Old 01-28-2008, 05:36 PM
Peter. i did not but that is good to know for next time.
  #11 (permalink)
Old 01-29-2008, 08:35 AM
Evan Grugett Evan Grugett is offline
Was the flame in the gas burner yellow instead of blue, meaning out of tune? How old was the heater, it may be beyond its useful life. You could check for flue gas problems with a hand held combustible gas detector. This condition must be checked and corrected by a licensed plumber ASAP! The other comments about combustibles near the unit, height of the burner above the garage floor, and perhaps flex or copper gas piping penetrating the wall (not visible in the picture) are appropriate reporting for these conditions.
Evan Grugett
  #12 (permalink)
Old 01-29-2008, 03:51 PM
Mike Schulz's Avatar
Mike Schulz Mike Schulz is offline
That galvanize gas pipe should be black pipe. Zinc coating flakes and particles can clog orifices.
Mike Schulz License 393
Affordable Home Inspections
www.houseinspections.com
  #13 (permalink)
Old 01-29-2008, 07:59 PM
Quote:
I don't know that there is a prohibition against using galvanize pipe.
  #14 (permalink)
Old 01-30-2008, 06:41 AM
My brother in-law told me that. He does commercial HVAC. I just always figured it to be true because it's always been black pipe and flex.
  #15 (permalink)
Old 01-30-2008, 07:04 AM
Matthew Skowron Matthew Skowron is offline
Jim Z. said it best ALL gas water heaters at one point WILL have flame roll out due to poor maintnance. burners cake up with debree rust away. I do agree that backdraft could play a part but doutful in a garage if in a house just inside the door to a house i can see that from de-presureing the house when a door is opened.
  #16 (permalink)
Old 01-30-2008, 10:18 AM
Back when I was an engineer at a gas range component manufacturer, we had an AGA directive banning the use of zinc coated materials ( galvanized ) in products which would come in contact with natural gas. It is due to product liabilty / safety issues due to adverse chemical reaction of gas and zinc.
  #17 (permalink)
Old 01-30-2008, 10:59 AM
Ken Amelin Ken Amelin is offline
NFPA 54 "National Fuel Gas Code - 2006
Section:5.6.2.2 - Steel and Wrought Iron. Steel and wrought iron pipe shall be at least of standard weight (schedule 40) and shall comply with one of the following standards:
(1) ANSI/ASTM: B36.10 welded and seamless wrought steel pipe.
(2) ASTM A53, Standard specifications for pipe, steel, black, and hot-dipped, zinc coated welded and seamless.
(3) ASTM A106, Standard specification for Seamless carbon steel pipe for high-temperature service.
  #18 (permalink)
Old 01-30-2008, 05:48 PM
How strange,
If you google Galv gas pipe you will find mixed reviews. Some say yes some say no. All I know is that I never see it unless a home owner installs it. It makes sense to me not to use it because of the zinc. Maybe because of the diffrent grades of galv. that it's not used and because of not installing the right stuff.
How many of you guys out there use Galv. when you install pipes in homes? and why?
  #19 (permalink)
Old 01-30-2008, 07:30 PM
How It makes sense to me not to use it because of the zinc.
Know those thingys (technical term) which never seem to get installed, or are installed incorrectly when they actually do get installed?
You know ...
... "Sediment Traps"?
Yeah, that's what they do ... catch that stuff, if any, and other 'stuff' to keep anything from happening.
  #20 (permalink)
Old 01-30-2008, 11:30 PM
Donald Merritt Donald Merritt is offline
Dark areas above the burner areas of water heaters sometimes indicates that the interior flame shield for the burner area has not been installed properly and is allow combustion gasses out of the front of the burner area. Check to see if the interior flame shield has been installed with the top metal section inside the burner area. Also, the heat coming from the burner area can damage the solenoid valve for the water heater. Check the operation of the solenoid valve to ensure it has not been damaged.
Don Merritt
  #21 (permalink)
Old 01-31-2008, 06:30 AM
By the way ...
Quote:
Know those thingys (technical term) ...
That 'thingy' in the photo was installed properly with the sediment trap leg down and the gas coming into it from the top.
