You are currently viewing InspectionNews as a guest which gives you limited access to view most discussions but not pictures. There are over 4,500 inspectors who have already joined. By joining InspectionNews you will be able to see the pictures, have access to post topics, communicate privately with other members, respond to polls, upload content and access many other special features. Registration is fast and simple so please, join InspectionNews today!
Old 03-20-2008, 06:49 PM
David Block David Block is offline
Ever seen a flue like this?
I was on the roof of this house and took a peak down the one of the flues and this is what I saw. There were two flue tiles coming out of the chimney chase. One was for the furnace and water heater. The one in the picture was for the fireplace in the basement and the fireplace in the living room. The picture doesn't do this setup justice. There were two copper gas lines retrofitted into the fireplaces with one going through the cleanout door and the other, they just knocked a hole in the side of the flue liner and fed it through that way. It was quite the setup.
Old 03-20-2008, 07:11 PM
Re: Ever seen a flue like this?
I adjusted the brightness and contrast to show the inside better.
Construction / Litigation Consultant www.ConstructionLitigationConsultants.com
Old 03-20-2008, 07:15 PM
Thanks Jerry, that really brings out the details much better.
Old 03-22-2008, 04:14 PM
Bob Harper's Avatar
Bob Harper Bob Harper is online now
You're saying two fireplaces shared this one common flue? Let me get this straight:
common vented fireplaces
copper gas lines in the flue
tiles broken out
mis-aligned tiles
mortar missing/ eroded
gas line routed through chimney wall???
So, what was your recommendation or comment on this? Good catch.
Bob
Similar Threads
Gas Flue Dead End David Banks Plumbing System: Home Inspection and Commercial Inspection 10 03-08-2008 07:48 PM
HE Flue Venting Jim Robinson Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 1 02-18-2008 07:26 PM
Chimney flue Jeff Eastman Roofing System: Home Inspection and Commercial Inspection 1 12-03-2007 06:42 PM
Pre-Fab chimney flue Martin lehman Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 1 09-05-2007 10:08 PM
Flue in return air. Eric Shuman Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 1 08-04-2007 12:27 PM
vB.Sponsors
Ad Management by RedTyger
