Old 04-07-2008, 07:58 PM
daniel nantell daniel nantell is offline
brick chimneys
You see a lot of older homes that once used coal or fuel oil converted to natural gas, does the natural gas furnace need a liner installed in the old brick chimneyh to be legal or can you just tie the gas furnace into the side of the chimeny where the ole equipment was. thanks
dmn
Old 04-08-2008, 04:20 AM
John Arnold John Arnold is online now
Re: brick chimneys
Daniel - A liner should be installed. The gas exhaust is cooler and, I believe, contains more water vapor than coal or oil. Aside from the fact that all that condensate will damage the old masonry flue, the flue is probably also too big for the gas furnace, which just makes the problem worse.
Home inspection
Similar Threads
Vinyl over brick Richard Roshak Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 12 11-04-2007 10:27 AM
Abandoned Chimneys Still Functional James Duffin Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 1 07-07-2007 07:16 PM
Painted brick James Napier Building Envelope: Home Inspection and Commercial Inspection 19 05-26-2007 12:30 PM
Brick David Banks Building Envelope: Home Inspection and Commercial Inspection 5 05-19-2007 06:06 PM
Brick displacement Jeff Eastman Structural Components: Home Inspection and Commercial Inspection 6 05-10-2007 07:44 PM
vB.Sponsors
Ad Management by RedTyger
