Welcome to InspectionNews.
Registration is FREE!
The Cost Of Business
Old 04-20-2008, 01:39 PM
Jerome W. Young Jerome W. Young is offline
gas water heater in laundry room
I found this in an older house. It is a gas water heater in the laundry room. It is a 1996 model. It did not have the sealed burner/pilot area.
This should have an external fresh air intake? 18 in. stand?; etc? Should it have a mechanical vent as well?
I saw some burn marks and it appeared to be from some flame roll out at some point.
FREA Home Inspector Insurance
Old 04-20-2008, 02:16 PM
Jim Robinson's Avatar
Jim Robinson Jim Robinson is online now
Re: gas water heater in laundry room
Where is the garage in relation to the laundry room? What type of door or doors between the house / garage and laundry?
Old 04-20-2008, 02:23 PM
James Duffin James Duffin is offline
If the garage is not an issue then you don;t need the 18" high stand. As far as the fresh air intakes go, you need 50 CF of space for each 1000 BTU of burner capacity. If the WH is 32,000 BTU's you need 1600 CF of room area to avoid needing the external combustion air intakes. This would be a 14 x 14 room with a 8' ceiling which I doubt the laundry room is.
Old 04-20-2008, 05:16 PM
Billy Stephens's Avatar
Billy Stephens Billy Stephens is online now
Quote:
Originally Posted by Jerome W. Young View Post
--etc?
TPR discharge line, drain pan, galvanized cold intake line ect ( New WH.)
Old 04-20-2008, 06:10 PM
the laundry is open to the rest of the home. It had louvered doors surrounding it.
  #6 (permalink)
Old 04-20-2008, 07:04 PM
The adjacent rooms can be counted for your CF calculations as long as there is no door between the rooms.
  #7 (permalink)
Old 04-20-2008, 10:00 PM
I've always been surprised that dryers can be right next to water heaters. It sure seems like all of the air a dryer is sucking up could pull air down the water heater vent. I suppose with adequate fresh air this doesn't happen. It just seems to be pretty close to a problem. But, codes and specs are written from actual tests/studies and not my idea of what could happen.... So, I imagine it's okay.
  #8 (permalink)
Old 04-20-2008, 10:03 PM
Be sure to include the gas dryers BTU's when calculating your fresh air requirements.
  #9 (permalink)
Old 04-21-2008, 05:03 AM
Timothy M. Barr Timothy M. Barr is offline
I would be more concerned about the pressure relief valve not being extened. What is the silver stuff on the outside of it? insulation?
  #10 (permalink)
Old 04-21-2008, 03:39 PM
yes insulation ans yes the tpr is a concern and noted
  #11 (permalink)
Old 04-21-2008, 04:59 PM
John Arnold John Arnold is offline
I see a lot of added insulation (not that silver stuff, though) where it is blocking combustion air at the bottom either because whoever installed it didn't know any better or because over the years it slipped down. Not good.
Home inspection - The Cost Of Business.
Similar Threads
gas water heater Jerome W. Young Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 25 07-19-2008 11:12 AM
Hot Water Heater Tom Rees Plumbing System: Home Inspection and Commercial Inspection 3 04-02-2008 09:35 PM
Laundry Room Exhaust Fans mathew stouffer Built-In Appliances and Systems: Home Inspection and Commercial Inspection 2 03-08-2008 06:47 PM
Laundry Room and Dryer Exhaust Vents Clay White Built-In Appliances and Systems: Home Inspection and Commercial Inspection 51 10-31-2007 08:37 AM
Water Heater Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 5 07-23-2007 06:31 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Ad Management by RedTyger
