Old 06-04-2008, 12:17 PM
Nick Ostrowski Nick Ostrowski is offline
Heat Distorted Vinyl on Wood Burning FP Chimney
I saw this yesterday while inspecting a 6 year old house with a wood burning fireplace. The pics are of the exterior chimney structure.
What would your initial thoughts be?
Old 06-04-2008, 12:21 PM
wayne soper's Avatar
Re: Heat Distorted Vinyl on Wood Burning FP Chimney
Same as yours. Call maufacturer for install instructions. Unit may have to be pulled to determine problem. Is there fan circulation around the firebox. That could be sucking the heat out of the unit. Might be easier and cheaper to remove the siding and plywood to look from behind.
Old 06-04-2008, 01:03 PM
Reflected sunlight off those windows.
Does it every time (well, many times) to vinyl siding. Combine that with possible not allowing for enough expansion when the vinyl siding was cut to length and installed - yeah, that could be the cause.
Old 06-04-2008, 01:51 PM
Ron Bibler Ron Bibler is online now
This may piss Jerry off. But thats not hard to do. L.O.L.
Love ya Jerry.
Get a fire going and Put an Infrared Camera on the out side of that chimney. If its hot in that area you will see it.
Take a shot before and after the fire.
Best
Ron
Old 06-04-2008, 01:58 PM
Billy Stephens's Avatar
Billy Stephens Billy Stephens is offline
Quote:
Ron
And as the Fire Trucks Arrive & As they leave.
Billy J. Stephens HI Service
  #6 (permalink)
Old 06-04-2008, 02:14 PM
You don't have a little arson in your blood do ya Billy? L.O.L.
Best
Ron
  #7 (permalink)
Old 06-04-2008, 02:21 PM
Best
Ron
A buddy of mine has a Fire & Water Restoration Company.
When I'm not busy I help him out. Just finished gutting one ( a BQ mishap . )
Just a matter of time & maybe some Xmas paper stuffed into the fire box to touch that one off.
  #8 (permalink)
Old 06-04-2008, 02:42 PM
Jerry wins the cupie doll. Take a look at this interior shot of the firebox...........practically spotless with the exception of maybe some candle wax. Also, take a look at the melted gasket inside the window/magnifying glass that was adjacent to the fireplace. I saw another window in the house with similar damage and the same orientation to the east facing morning sun.
When I saw the fireplace had not been used, my only thought was it had to be the sun refelecting off the adjacent window.
Luckily just to cover all bases, the fireplace had a few issues that needed some servicing from a fireplace professional such as misaligned retaining clips in the firebox for the legs of the log grate and gaps between the glass door assembly and surround on front of the fireplace.
  #9 (permalink)
Old 06-04-2008, 03:25 PM
I know, you sent Jerry the fireplace pic didn't you? HAHA Good call Jerry,
  #10 (permalink)
Old 06-04-2008, 03:28 PM
Jerry you Da Man!!!
Good eye. Insider info ?
Best
Ron
  #11 (permalink)
Old 06-04-2008, 04:09 PM
Bob Harper's Avatar
Nick, you were taught well!
Actually guys, this has been discussed on this forum before. Yes, it is the combination of reflected light off the glass in conjunction with tight siding. On broad walls, they use full panels. When they do make cuts, it is to one side only. They only negotiate one corner channel at a time. Now, with chases, they have to make more precise cuts, don't have a lot of room to nail (maybe two nails per course) and they are frustrated with having to think. I find the side panels snapped in they are cut so long. The few nails sometimes are fully driven in to keep the siding from bulding out. The sunlight phenomenon is usually on southerly exposures.
Ron, if you can read any degree of heat differential on the side of a chase that can be directly attributed to a hot flue or fireplace, you probably have other problems. The testing allows a maximum rise of interior surface temps. of 90F above ambient at the stated clearances. These sides are usually a foor or more away from the unit, thus are usually much cooler. For enough heat to migrate through would mean something is really wrong such as gaps in the sheathing, a disconnected vent or overfiring fireplace.
Good pickup Nick!
Bob
  #12 (permalink)
Old 06-04-2008, 04:23 PM
Oh Well,
Maybe next thread.
  #13 (permalink)
Old 06-04-2008, 04:37 PM
I like Billy toys lets all go play at his house. L.O.L.
Ron
  #14 (permalink)
Old 06-04-2008, 09:44 PM
Erby Crofutt's Avatar
Erby Crofutt Erby Crofutt is offline
My first thought was an idiot put his grill to close to the house.
Secod was sunlight off the windows.
Erby Crofutt, Georgetown, KY
B4U Close Home Inspections & Radon Testing
www.b4uclose.com www.kentuckyradon.com
  #15 (permalink)
Old 06-05-2008, 10:38 AM
Brandon Chew Brandon Chew is offline
Vinyl siding is popular around here, and I've seen this a few times. Heavier thickness vinyl and lighter colors are still susceptible to this problem.
The problem with this situation is that the siding manufacturer will blame the window manufacturer. The window manufacturer will blame the siding manufacturer.
The solution is to either screen the sun from hitting the window, screen the reflection from hitting the siding, or choose not to wrap your house (or that portion of it) in plastic.
  #16 (permalink)
Old 06-05-2008, 05:06 PM
Bob Harper's Avatar
solution
Or install the siding properly....
BTW, they DID wrap the house in plastic-----that's what lead to this in the first place!
Bob
  #17 (permalink)
Old 06-06-2008, 11:17 AM
Installing the siding "too tight" by driving the nails too deep or by not leaving enough of a gap at the J-channel can certainly make the problem worse. But I've seen this happen to high quality vinyl siding that was properly installed, even in the center of long walls where room for expansion is no issue. The reflected sunlight can get the siding so hot that it just melts it in place. This happened in upstate NY which is not known for its intense sunshine.
There's a thread on this problem at The Inspector's Journal forum that has been kicking around for a while. In that one, the siding on the house is being damaged from a reflection off the window of a neighbor's house. Now there's a tough solution....
Similar Threads
boiler providing steam heat and hot water heat Peter Ottowitz Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 4 05-28-2008 11:33 PM
Venting Oil furnace and Wood Burning Fireplace Reis Pearson Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 4 03-04-2008 11:35 PM
burning salt water Jerry Peck General Chit Chat: Home Inspectors & Commercial Inspectors 10 06-25-2007 04:31 PM
Wood Burning Fireplace Dale W. Feb Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 12 04-16-2007 03:08 PM
From the old board, light bulbs incessantly burning out Tim Moreira Electrical Systems: Home Inspection and Commercial Inspection 0 04-02-2007 12:55 AM
