Old 07-07-2008, 09:43 AM
William Galbraith William Galbraith is offline
Gap between wall and fireplace
I found this gap between the wall and fireplace inside the firebox. The bottom gap is about 1/4 inch, the side gap is slightly wider and the gap at the top of the firebox is over 1". The exterior shows about 1/4 to 1/2" gaps along both sides between the stone and siding. The home is over 30 years old so settling has occured. Good old red clay of Oklahoma. That is why we have ACME brick located here.
The exterior fix should be easy with mortar. Is there special mortar that must be used to repair the inside because of high temperature? I imagine it should be a relatively dry mix.
Old 07-07-2008, 01:13 PM
Cary Seidner's Avatar
Cary Seidner Cary Seidner is offline
Re: Gap between wall and fireplace
Yes. You need to use refractory mortar in a fireplace.
Old 07-08-2008, 10:55 AM
Darren Miller's Avatar
Darren Miller Darren Miller is offline
Fixing the gaps will be a temporary fix; the crack will only open again due to settlement. The settlement problem needs to be addressed.
I had one a little worse than this about 8 years ago; cost $30,000 to tear down and re-build. It was a fireplace but also had a flue for the boiler & water heater.
Darren
Succasunna, NJ
www.aboutthehouseinspections.com
Old 07-08-2008, 12:11 PM
Nick Ostrowski Nick Ostrowski is online now
Quote:
I thought the same thing Darren. In pictures #2 and #5, you can see the displacement in the cracks. In #5, it appears the area was repaired/patched once and has cracked again. Cracked patches are one of the easiest ways to guesstimate whether or not the issue is ongoing.
Similar Threads
Single Wall vs. Double wall vent pipe Jonathan Clevenger Plumbing System: Home Inspection and Commercial Inspection 2 03-08-2008 11:10 AM
Gas line in fireplace Paul Kondzich Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 3 01-14-2008 02:52 PM
Fireplace opening dan orourke Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 2 12-03-2007 08:17 PM
Fireplace help Jim McClendon Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 1 09-14-2007 09:36 AM
Outdoor fireplace Jeff Eastman Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 15 06-06-2007 09:20 AM
vB.Sponsors
Ad Management by RedTyger
