08-14-2008, 12:43 PM
Metalbestos chimney at deck
I found this chimney which is improperly secured to the deck railings and does not meet the minimum height 2' above anything within 10'.
I was not sure if there would be a requirement to install some protection around the chimney at the deck area.
It does not look right but I can't find any info on this type of install.
08-14-2008, 01:06 PM
Re: Metalbestos chimney at deck
Found this. Do not have time to look it over.
Dave
08-14-2008, 01:19 PM
That "within 10 feet" is for chimneys. For Type B gas vents it is "within 8 feet". Looks like it might meet that?
08-14-2008, 01:36 PM
Sorry, this is a wood burning free standing stove chimney, I should have mentioned that.
08-14-2008, 02:44 PM
Is it outside, like on a covered patio or is that deck over the roof of a room in the house and the stove is inside the house?
08-14-2008, 09:08 PM
Chimney must be protected from contact or physical damage and properly supported.
Bob,
from SC
08-15-2008, 05:22 AM
It is a free standing stove in an addition with a metal roof and a deck on top of the metal roof.
08-15-2008, 06:57 AM
just some common sense notes:
that strapping most likely will cut you if your not careful, and hanging out on the deck at night or if the deck had a few folks on it and someone pushed someone else i could see where you might be bleeding soon.
I would not leave this pipe standing where someone could get to like that cause eventually some nut is going to tie something to it, lean against it, have something on the deck and have something fall against it, etc.. That strapping is there to keep the wind from blowing it over.
not to mention that it looks (to me...but no one asked my opinion on that) like crap standing there on the deck.
I'd cover that baby with something decorative ... more wood around it would seem appropriate... that way if you needed to extend the pipe to meet code...no biggy...
08-15-2008, 11:05 AM
I agree, it does look terrible.
Thanks for the input
08-15-2008, 11:27 AM
Actually, it is a "biggy".
Anything you cover that with will just become a largeR 'sail' and be blown over in the wind easIER.
If you intend to build a wood chimney enclosure around it, you need to allow for minimum clearance from the chimney, supporting the chimney tie-offs, and have a structural engineer design the appropriate structure and how-to-heck-to-keep-that-structure-from-falling-over-in-the-breeze.
08-15-2008, 12:03 PM
yea, that chimney is not rocket science though. I've built tons of them covering that size pipe. 24 X 24 inches will cover it. it just needs to meet the height requirements for the jurisdiction and just plain ole good building practices. the difference with this deal though is how it would have to be braced. normally there is a roof to come out of and my chimney corners would have been brought up from the attic where I could get some good bearing strength. this thing (if they decided to cover it) would have to be paid attention to...i don't think this chimney could just sit on the deck without some kind of help to keep it from blowing over.
the sad part of all this code stuff is that the house has to be in an area that follows or enforces a code to begin with. there are over 60 counties in Mississippi that have no code at all. the home owner/builder/remodeler/anyone can do what the heck they want.
Mississippi isn't the only state without a uniform code...
| Thread Tools |
Search this Thread |
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
| Deck Framing |
Joseph P. Hagarty |
Exterior Systems: Home Inspection and Commercial Inspection |
2 |
07-05-2008 05:41 AM |
| Big Deck |
David Banks |
General Chit Chat: Home Inspectors & Commercial Inspectors |
0 |
03-09-2008 02:35 PM |
| Deck Construction |
Scott Latosky |
6 |
02-26-2008 02:38 PM |
| Deck Spindles |
Matt Fellman |
1 |
01-09-2008 06:32 AM |
| Deck flooring |
dan orourke |
4 |
06-20-2007 10:53 PM |
