Re: Clearance (Bob Harper?)
I don't know exactly because I'm not intimately familiar with this termination. That's why I deferred to the listed instructions. If the termination is not damaged or tampered with, then you are still looking at factors within the fireplace itself for the sooting. What is causing the sooting could be an all day class in and of itself so suffice it to say this fireplace needs service by a qualified technician.
As for the soot patterns on the exterior, you can have a proper installation that still causes soot deposition, melting siding, etc. In that case, I recommend you still call it out because obviously it is still having problems. Listings are not bullet proof. They represent a set of proven performance values that somebody in authority has accepted that under most generally anticipated conditions, will perform acceptably. Not Superman's cape.
Bob
