Old 09-05-2008, 05:58 PM
Thomas Hudson Thomas Hudson is offline
Fire caulk needed?
I inspected a pre-fab Desa fireplace today on a new home and have a quick question. This was set up for wood burning with the fake brick interior. The back fake brick panel was loose and there were gaps between the side panels and the back panel. I looked at the instruction manual and saw no reference to sealing that joint. I know there is supposed to be metal around the firebox but it seems these joints should be sealed. Thoughts?
Old 09-08-2008, 03:39 PM
Re: Fire caulk needed?
Anyone? The reports written, but I'm still curious what others think.
Old 09-08-2008, 04:06 PM
Bob Harper's Avatar
I was hoping I could draw out a response from one of the home inspectors to see if any of them knew.
No, you do not caulk the refractory panels in factory built fireplaces. The gaps are there to allow for thermal expansion. However, the gap should be a pontential one. If the panels have separated to the point you can see the sheetmetal firebox wall behind them, then I suggest you refer the matter to the installer, preferrably one who is an NFI certified wood specialist. Usually, all it takes is to remove the panel, tweak the spacers behind the panel then reinstall it.
HTH,
Bob
Old 09-09-2008, 09:30 PM
Thanks Bob, thats how I wrote it up but wasn't 100% sure if I was correct. I really appreciate your insight. Good Karma to you, keep em safe!
Similar Threads
Caulk Needed at Hardiplank joints Scott Dana Building Envelope: Home Inspection and Commercial Inspection 42 11-08-2008 06:12 PM
Fire blocking needed? fritzkelly Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 12 09-06-2008 08:20 AM
caulk on flashing joints John Stephenson Roofing System: Home Inspection and Commercial Inspection 4 06-24-2007 07:35 PM
SE needed or not? John Stephenson Structural Components: Home Inspection and Commercial Inspection 7 05-26-2007 08:22 AM
caulk that crack says SE John Arnold Structural Components: Home Inspection and Commercial Inspection 6 04-12-2007 02:33 PM
vB.Sponsors
Ad Management by RedTyger
