Old 10-03-2008, 04:15 PM
Richard Roshak Richard Roshak is offline
Attachments to chimney
Does anyone have a good technical paragraph for when attachments have been made to a masonry chimney? In this home the porch structure and service cable where attached and approved by the local building official and utility company.
Rich
Old 10-03-2008, 06:26 PM
Re: Attachments to chimney
Quote:
How about:
Hey, stupido, you are not allowed to attach framing to a chimney, in fact, you are required to keep the framing 2" away from the masonry chimney - you got some 'splainin' to do, Bozo.
By the way, Bubba, you trying to pull that chimney down with the overhead service? Jeez, might as well try and remove one brick at a time, 'cause that's what you're tryin' to do.
Old 10-03-2008, 07:01 PM
John Arnold John Arnold is online now
Sorry, Jerry, but he said "technical" paragraph, and "stupido" just doesn't make it. I believe "Knucklehead" is the preferred technical term.
Old 10-03-2008, 07:41 PM
Raymond Wand Raymond Wand is offline
Not to mention how the service conduit enters the gable end shingles.
The porch does not appear to be attached to the chimney. I don't see any lag bolts. Were they present?
The value of experience is not in seeing much, but in seeing wisely. - Sir William Osler 1905
Old 10-03-2008, 07:49 PM
Quote:
(slap to forehead)
What was I thinking?
Richard,
All in good fun, and there is technical information in there for you to use.
Similar Threads
Chimney Zibby Swieca Roofing System: Home Inspection and Commercial Inspection 2 03-27-2008 08:03 PM
B-vent chimney Brian E Kelly Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 3 12-08-2007 07:23 PM
Chimney Fun Nick Ostrowski Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 4 07-06-2007 09:18 PM
Chimney within a chimney Jon mackay Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 8 05-09-2007 10:37 AM
Chimney within a chimney Jon mackay Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 0 05-08-2007 12:51 PM
vB.Sponsors
Ad Management by RedTyger
